By KRYSTED9354
#51167 FIRST off i have searched on ebay,honda-tech,google, and cant find the info im seeking fro which is,
the difference between the Z6 and A6 timing belts!
here is what i got so far.
D15B7 106 teeth
D15Z1 104 teeth
D16Z6 103 teeth
D16A6 :? :?
cant find the d16a6 teething ? if any body know please fill in, thanks
and again isearched and only found that info when i type in D16A6 timing belt specs or teeth it just came up to mini swaps, and adjustment's and other specs.
#51179 d16a6 has 107 teeth - too loose for your application.
d16z6 is too tight, try the D15b7. it may seem loose at first but after you adjust the tensioner it should be alright :thumb:
By KRYSTED9354
#51181 i have the z6 on right now, but it was used so i have to change it ASAP !!
and my kit came with a D16A6
i might just go to autozone buy a NEW D16Z6 and the put the A6 in the box and return it LOL LOL hah what ya think ?
By KRYSTED9354
#51182 OH and thanks !
By KRYSTED9354
#51183 here they say http://honda-tech.com/zerothread?id=554053
{ IMPORTANT: Several places on the net and several people on Honda-Tech say that the VX (D15Z1) timing belt is the one to use for this swap because it is for a 1.5L VTEC. THIS IS INCORRECT! When I did the initial head swap, I used a VX timing belt. The VX timing belt was WAY too tight, and whined when the engine was at high rpm. I unfortunately did not discover this until the entire head was assembled. The VX timing belt has 103 teeth, where as the Z6 timing belt has 104 teeth, and the B7 belt 106 teeth. I was finally able to replace the VX timing belt with the Z6 timing belt, and the Z6 timing belt fit much better and didn’t whine. THE D16Z6 timing belt is the correct belt to use with a B7 block / Z6 head combination
but i have a D16a6 , not sure, ill mix and match, also instead od adj cam gear can i just move my distributor back and forth to impruve and tune timing ? thanks again
#51184 did you read what I posted? don't buy a z6 tb :idea:
cam gear is for engine timing, adjusting the dizzy is for ignition timing. 2 different types of timing. one matched the cam with the crank, the other tells the spark plugs when to fire.
By KRYSTED9354
#51185 ok sorry ,i just read what they said to use the z6 and some say use the VX ,also i used the d16a6 headgasket and it seemed fine any tips ? can it be used or no recomend ? thanks oh and so u think ill be fine with stock cam gear as im now ? thanks
By id3379
#51186
KRYSTED9354 wrote:i might just go to autozone buy a NEW D16Z6 and the put the A6 in the box and return it LOL LOL hah what ya think ?
i hate thief's to any degree.
By KRYSTED9354
#51187 oh like u havent,its not thieft its exchange
