- Fri Apr 25, 2008 1:04 am
#52515
My tranny has just developed the 2nd to 3rd gear crunch when shifting at mid to higher RPM's. Figured it was a good time for me to learn how to rebuild a tranny
I got it apart today and I was expecting to see some really bad wear, but I guess because I stopped driving it shortly after it started grinding, I didn't cause too much wear.
I was looking for rounded teeth on the synchros, but they all looked OK and sharp. Here's some pics for the tranny guru(s):
on the mainshaft:
5th Gear Synchro & sleeve:
synchros look good to me (having never seen a new or worn one before)
How about that sleeve, any wear?
looking further down the mainshaft to 3rd-2nd:
now looking at the countershaft:
the 2nd & 3rd gears are the 2 gears side by side on the lower right
I don't have a press, so I couldn't get the sleeve off the countershaft.
What I'll probably end up doing is ordering the new parts I need and dropping off the mainshaft & countershaft at a shop with a press and paying them to replace the worn parts.
The only thing that looks a little worn to me (tranny noob) is the matching synchro teeth on the 3rd gear on the countershaft.
If possible from my pics, can someone tell me what looks like it needs replaced?
on the mainshaft:
My 1992 SOHC Turbo Hatch
