- Sat Oct 14, 2006 6:16 am
#185
I'm a little hesitant to post her pictures since most of these cars are modded up. But, here she is!
After trying auto-x in my 1985 300ZX N/A Auto. and her 01 Accord EX Sedan Auto., we decided we needed a better car. We sold the Z and bought the Si earlier this summer.
The car was almost totally box stock. It had tint on all the glass except for the hatch, an unknown aftermarket muffler (only), and a CD player with a large woofer/amp/box. That's IT! Well, and it had the red "Si" badge, in place of the oem sticker. It still has the resonator and even had the ORIGINAL plug wires (dated 1993 clearly visible!)!
Mods so far:
K&N drop-in
MSD Supercondutor wires
ES Shift Stabilizer bushings (red...as if you could see them)
ES End Link bushings (red)
CRX Si Alloys (1st Gen)...saved about 15 pounds!
5mm Wheel Spacers
Switched to Red Line MTL in the tranny
Switched to Durablend in the crankcase
Removed the woofer/box/amp...saved 25 pounds!
Removed the cargo cover...I think that was maybe 10 pounds
Switched to synthetic brake fluid (and flushed the system!)
"Seafoam" intake treatment
"Lucas" fuel injector treatment
Planned mods:
Koni Yellows
Falken Azenis tires
Kumho V710's (auto-x only)
OEM Cat
Cat-Back Exhaust
Red Line in the crankcase
ES Sway Bar body mount bushings (on back order!)
Considering an oil catch can
Considering changing to silicon vacuum lines...color coordinated
Need to index the PLUGS!!!
Future Mods...when/if we move to STS:
HX wheels
Complete ES Bushing Kit
Reprogrammed ECU
Eibach Springs
Prolly several others, but this is over a year away.
We'll finish this season with about 10 events under our belts, with no serious mods to the car. Off-season we'll take most of the Stock allowances and run next year in HS.
Hope you like it!
Remember..."Civic spelled backwards is "civiC"
Mods so far:
K&N drop-in
5mm Wheel Spacers
Planned mods:
Koni Yellows
Falken Azenis tires
OEM Cat
Cat-Back Exhaust
HX wheels
Reprogrammed ECU
Eibach Springs
Hope you like it!
