So what year is your car?
My 1992 SOHC Turbo Hatch
Greasedmonkey wrote:if you use a y8 head, the stock dx dizzy will bolt right up.
As for the z6 head, you will want the z6 dizzy. Im not sure what other ones will bolt up.
Ylts wrote:yes i Bought a donor for swap and lifted all things to D16A6 block, ECU from Z6
NB! read first post
d-mon wrote:Ylts wrote:yes i Bought a donor for swap and lifted all things to D16A6 block, ECU from Z6
NB! read first post
i read all the post.
are you sure you have a z6 distributor?
is it a td-42u?
teal_dx wrote:Also, did you remove the oil control jet from between the #2 and #3 cylinders on the block?
