By chrisscott
#202704 anyone had this done.
what will i gain hp wise roughly.
only got cat-back exhaust an air filter
oh yeah on a D16z6
By blk92hb
#202721 Oh yea it does. I also had a slunk2 cam, cam gear, and high comp valves. But you can tell a difference im the power band. It also made it sound different it sounded more throaty it was sweet i would do it if i where you. Im also going to do it to my b16a just because i like the yay it sound and performed :thumb: :thumb:
By dro21
#202724 HP gains arnt much..all it does it makes the air/fuel flow to go in and out more smooth.
By VerLee24
#202727 first of all, im hoping that you wouldn't hack at it with a dremel yourself but pay a shop to do the work.. in this case.
HP gains aren't much if you just leave it at PnP.
the name of the game is air flow. the more air you can get in and out the more power you can make.
compaired to a straw, would you rather suck through a bubble tea straw or a coffee straw?
but just a PnP? thats like sucking through... a coffee straw that bulges to a fat straw in the middle and then back to a coffee straw... kind of pointless if you dont have it at both ends eh?
PnP, header, exhaust, cam, oversized valves, ITBs... oh wait.. why would you be going n/a with a d16z6 anyways...
save your money and boost it.
By dro21
#202742
VerLee24 wrote:first of all, im hoping that you wouldn't hack at it with a dremel yourself but pay a shop to do the work.. in this case.
what are you smoking..Na d16 are beastly especially if done right..
By VerLee24
#202747 what is your definition of beastly? granted if anything is 'done right' you can have a 700whp sohc bisimoto style. however, most of us dont have that kind of budget. Of course if you have enough money anything is possible.
n/a
http://jgenginedynamics.com/_dyno%20pdf ... %20pic.pdf
226 HP on 100octane with a 5000$ motor.
boost
http://img244.imageshack.us/i/image011wq4.jpg/
234HP on 93 octane with a stock d16y8 and a 2000$ turbo kit.
dro, what does this have to do with a port job anyways?
By dro21
#202758
VerLee24 wrote:what is your definition of beastly? granted if anything is 'done right' you can have a 700whp sohc bisimoto style. however, most of us dont have that kind of budget. Of course if you have enough money anything is possible.
n/a
boost
im just saying some people dont want to follow the boost bandwagon...yea boost is cheaper and going Na could be costly..Not everyone gets lucky to get a well maintained 15-18 yr old engine that you could boost right off the bat...
By chrisscott
#202789 the plan is to boost a D16 at a later date, but was going to buy another block and build it over time. so im just looking to make a bit extra power on the engine ive got in.
thinking bout P&P this one, get a manifold and a decat, and cam it in a couple of months, then get my garage to chip an tune it.
oh an no im not doing it myself, i want the engine to run again :D
By Randull
#205358 Hey guys,
I kind of wanted to chime in slightly because after talking to a few companies yesterday at Spocom there are some factors that must be taken into consideration regarding a PnP
The first thing is that it will help but it must be done appropriately. The polishing part is where things can get weird. I have seen quite a few people do these high finish polishes in there head but in fact it is doing nothing but hurting the potential ability to make power. In fact, that type of polish keeps fuel from properly atomizing and mixing and allows it to flow on the hug the surfaces rather than to mix with air.
In actuality, a rougher finish will create turbulence on molecules trying to hug the surfaces and bounce them into air molecules giving you a better mixture. So in actuality, a PnP will help out but it has to be done right or it may end up being more detrimental
-randy
By Eg6H2D
#205369
Randull wrote:Hey guys,
-randy
Finally someone who actually understands and did their research. =]. u took the word right out of my fingers..
Check this site out. u can learn alot.
http://www.jgenginedynamics.com/Shortblocks%20main.html
Head work.
I will try and keep this simple. To many times we engine builders make things to complicated and hard to understand. As a rule of thumb when we port a head, we will build it to flow the most it can with out killing our velocity. (air speed) The trick here is simple. Here is an example. Stock B16A intake port flows appx 235 cfm@28'' . This is at 450'' lift and at that lift the velocity is appx 92-93% of the port. If we increase the flow to say 285cfm@28'' and maintain the 92-93% velocity of the port, then obviously the head will make more Hp. It would be impossible not to make power. On the other hand, if we increase the flow to 285cfm@28'' but loose velocity and it drops down to say 70-75%, then this head in all likely hood will loose power over stock or not make any power difference at all. At best it will loose throttle response and make the same top end power. ( We see this allot and we usually can't fix them.) From our experience it takes appx 2.5cfm in a Honda engine to make 1 Hp. Now there are certain instances where port volume is necessary and so sacrificing velocity is ok, but you really need to know what your doing. Some examples would be full drag race only set ups, when using methanol fuels, big Hp turbo applications or full NOS set ups. Now in saying this keep in mind that these are our opinions and should be taken as that. Opinion. We will build your head for the best possible performance to meet your needs. 70% of all the head work we do is done by CNC or conventional machines.
:thumb:
By flyinryan122
#205543
-randy
Polishing is done only on the exhaust side of things, due to what you stated. way to do your homework lol.
hents why if someone is going to do this, PAY someone who knows what they are doing.
If you're going to port a head, you should just save it for your build. Leave the daily the way it is, nice and reliable.
Dumping money into something you're still driving and trying to make ''fun'' and get more power out of, is just taking money away from doing your build. Which will make your build take a very long time
