- Fri Feb 18, 2011 2:36 am
#239339
it's time to replace the clutch Master cylinder.
I've done a few but never took pics to write up a how-to. It's easy though.
disconnect the clutch pedal from that rod by pulling the pin out. Then go under the hood and remove the clutch line from the master cyl housing. Also disconnect the 2 wires going to the plastic tank, or maybe they only go to the lid- if that's the case then just remove the lid.
Then go back under the dash and remove the nuts on the bolts holding the clutch pedal to the firewall. Then the master cylinder will be loose and you can pull it right out of the engine bay.
Install in reverse order and then bleed the clutch line when youre done by using the bleeder screw on the slave cyl.
My 1992 SOHC Turbo HatchMy Youtube Channel: 6th Gear Garage
