- Thu Sep 08, 2011 8:58 am
#270834
There doesn't seem to be much info on this motor. Just curious if I could swap the head with a b7 or d15b head just for fun. I never see this motor modded and I'm just curious if I could bring anymore out of it for pick your part cheap. Not looking for any suggestions on a full motor swap as I already have a B18 it just won't be in for a little while so while I wait i'd like to have a little more umph to rotate my long cx gearing a little better (merging is scary with only 60 HP and a tiny car). The stock head leaks pretty bad into the Sparkplug holes and causes spark problems sometimes. Ive already changed the valve cover seals so I'm guessing the head is warped, So it will be nice to replace it anyways, I'm just looking for a simple pick your part swap over. Don't really wanna spend more then $100-200 if possible and not to much crazy fab work. If not I wont worry about it then, and just wait till I finish the B. Although I really wanna see what I can get out of this motor with simple small mods just for fun.
Wicked wrote:There doesn't seem to be much info on this motor. Just curious if I could swap the head with a b7 or d15b head just for fun. I never see this motor modded and I'm just curious if I could bring anymore out of it for pick your part cheap. Not looking for any suggestions on a full motor swap as I already have a B18 it just won't be in for a little while so while I wait i'd like to have a little more umph to rotate my long cx gearing a little better (merging is scary with only 60 HP and a tiny car). The stock head leaks pretty bad into the Sparkplug holes and causes spark problems sometimes. Ive already changed the valve cover seals so I'm guessing the head is warped, So it will be nice to replace it anyways, I'm just looking for a simple pick your part swap over. Don't really wanna spend more then $100-200 if possible and not to much crazy fab work. If not I wont worry about it then, and just wait till I finish the B. Although I really wanna see what I can get out of this motor with simple small mods just for fun.
Yes you can put a B7 head on that block. Bolts right on. Use the B7 cam gear and timing belt though. D15B is VTEC, so you would be into mini-me territory. For the price range you are looking to spend, I suggest the B7 head.
